Mastiff won't start. This is not a problem I haven't been waiting for because she has been acting up lately. It was getting where when you turn on the key switch a hit the run nothing would happen, so I would turn switch on an off then hit the stop button and then the start and it would seem to work. The ECU lights up like usual but the ignition module does not lite up when the run button is applied. Not sure if the off/run switch is bad or contacts are dirty, ignition module is bad or the ECU is starting to act up. Hey at least it is at home and not on the road somewhere. I have been lucky in the 2 plus years of ownership, only had to change the battery so for. I have not done anything else other than maintenance (fluids). The bike has 5600 miles on it. Any advice on where to start looking would be appreciated.... Thanks Bruce.
