Using castro gtx synthetic on bulldog 07
hads
Just wondering if its ok to use this oil on 07 bulldog its not a vtwin oil and was told i should use this for better performance but i hate to stray for the manual unless i ask someone on here first
francoblay1
The Spaniard
Been using Amsoil till now and very happy with it... it has become harder to find near me so I shifted to
Spectro heavy duty platinium full synthetic oil, sae 20w50
Ruben
What kind of oil I can use for the primary and transmission of a big dog k-9 2006 I am using mobil 1 20w-50 syntetic for the motor and is great, this oil said can be use in primary and transmission but the manual said do not use syntetic oil in the transmission does somebody knows ?
TapioK
There is a reason manual says no syntetic, unless you don't mind slipping clutch. There are a many threads about oils, should be easy to find with search
Tapio
francoblay1
The Spaniard
Wonder how much performance boost different oil could really give
I don´t think oil is about "Performance Boost" but about taking care of your motor!
and I tell you what, I don´t know what oil my K9 had in it when I first got it but its rocker boxes sounded like a sewing machine... I went to Amsoil and all noises stopped!
francoblay1
The Spaniard
Check THIS out! :oldthumbsup:
BTW, I am using the same in Motor & Primary with no issues at all.
francoblay1
The Spaniard
BTW, the GTX is not a full synthetic... its a blend.
http://www.castrol.com/en_us/united-states/motor-oil/castrol-gtx.html
Unless you are using the Magnatec? http://www.castrol.com/en_us/united...nthetic-motor-oil/gtx-magnatec-motor-oil.html
And this type is only available n the following grades: 0W-20, 5W-20, 5W-30, 10W-30.
If you want to use Castrol, the one you should be using would be this one: http://www.castrol.com/en_us/united...l/4-stroke-engine-oil/power-rs-v-twin-4t.html
POWER RS V-TWIN 4T Engine Oil
awg
Its to my understanding that oil for motorcycles has zinc in it. Which automotive oils don't. We need the zinc!
Ruben
Does somebody know why my battery gets low soon, big dog k9 2006, every time i don't use the bike is connected to the charger
TapioK
Well, my charging is working, I have no shorts, my battery is in good shape. I can have both my Dogs standing about a month without charging and both fire up OK. -03 even without compression valves....
francoblay1
The Spaniard
What are you on about Tapio? we are talking oils here LOL (apart from Ruben that does not know his way around yet).
