HuskerChop
Great to see this site back up and running. Ive got a long standing prob needing some outside influence on. Been fighting a starting issue for some time. I decked my cylinders to zero deck, added 600 Tman cam couple yrs ago along with adjustable Thunderheart ignition. All was great. On hwy, bike started intermittently just cutting off. Cycle key and would mostly restart. Troubleshot and found once ign box got hotter, would cutout. Removed, sent to Thunderheart and they heated up unit, and duplicated problem. Sent me new box. Installed and since then been fighting very hard starting. Actually kills starter rotation and drops battery voltage to 6-8 then starts rolling and starts. Ive changed all pos and neg batt cables, triple checked attach points, installed 2 new batteries, function checked comp releases (pulled them and bench checked, and installed and verified actuation), changed starters. I even pulled spark plug wires so NO spark at start up. Still, every time, hit start button and its like it hydraulic locks, then starts spinning. I cannot figure this out. Im an aircraft mechanic and feel confident that I have covered everything minus something internally. I did all motor work myself. Also when i rolled hard on throttle, motor sounds like it is pinging terribly. Does not matter where ignition module is set, minimal advance or max, bike sounds as if pinging. However, runs a timed 1/4 mile at 12.3 @ 121 mph. Im lost. Runs great after getting started, and pinging. I did have one comp release(rear) that the shaft start coming out of is swedging internally. It had bout 7/16 travel versus approx 3/16. Replaced. I know this is long, just wanting to explain all i have done. Nothing done with crank sensor however, possibility maybe??? Thank you in advance for patience of this long post
