I always forget to take pics. but I started today when putting it back together.
The wires to the CR's come between the cylinder heads and go into the wrap under the tank. They are covered with braided steel. I have already at this point cut the wires and soldered the two green wires and two black wires together with another green wire to run to the starter and a black wire for ground. Used heat shrink tubing and then covered everything in liquid electric tape. Then I use some clear tubing and ran the wires down through the frame to under the seat.
I used a 15 amp in line fuse holder and soldered it in line, heat shrunk it and covered with the liquid tape.
I took the wrap off the wire bundle that holds the green starter wire and exposed a section of the wire to connect to. Maybe 8 inches from the end of the starter wire.
I wrapped my green wire to the exposed section and soldered.
Covered with the liquid tape then electric tape.
Put the wrap back around the wires used a hand full of cable ties on all the wires. Hooked the black wire I ran to the negative side of the battery, put the gas tank back on and fired her up. So good so far.
