headshothills
Yes, mine was missing bad too, I took plenty of video and you can hear the cylinder dropping, then it would catch, fire for a cycle or 2, then fall off again, it continued to do this idling. Many of the other conditions such as bog, poor throttle response, not lugging in lower RPMs, it just all compounded the problem which ended up be a group of things. Each issue helped contribute on its own to the bike running like crap, while the plugs themselves made the biggest difference, going through the rest put the bike back at 100%... I also changed out the Sock filter in the fuel tank... Better safe than sorry, if all those other things were that bad, why skimp, do it all, call it a day with piece of mind knowing its all cleaned and replaced....
