I have red lenses so I would not care. This is Louisiana man! would the light it's self work?I would suspect that they do not make a rear version, red instead of amber, as it would likely violate most states traffic laws involving spot type lights facing to the rear of the vehicle.
I'm gonna need to replace that connector .. where can I get 1 ?Yep, common issue with the BDs
Another great feature of the LED light, no real heat to deal with
White is the ground correct..
Low beam = 2 bulbs litdid anyone ever confirm for me?
low beam does all 3 LED diods lit? or just 2?
and when on High is it just that the 3rd diod lites? or do all 3 get brighter.
Could be that you wired up backwards.Well all 3 of mine are lit, so i guess when they har wired it they just wired it for bright ha. screw adding a button then
