Yes Rick, just like any brake you can bleed it by pumping the lever. The tool is no more than the simple plastic pump that you can get at your auto store down the street. It pumps fluid in from the caliper.Anyone bled your breaks on your BD. My service manual says there is a BD tool for this and you inject break fluid into the bleed fitting??? Can you just bleed them the old fashiond way and fill the res, & pump the lever and bleed out air out of the fitting??
R
I wouldn't think the air would come out since the master cylinder piston would be all the way in the bore and closing off the ports in the master cylinder.I picked up a tip on this today and wonder if any of you have tried it?
tie the lever down with something so the brake is full on - then remove the master cylinder cover and leave over night - all the air bubbles come to the surface and away they go. any views?
I was just telling another member about this meathod.I wouldn't think the air would come out since the master cylinder piston would be all the way in the bore and closing off the ports in the master cylinder.
Try back bleeding...get a new oil squirt can and fill it with fresh brake fluid. Get a piece of hose that has the inside diameter to fit over the bleeder. Hook the hose up to the oil can and start squirting. The brake fluid will flow up the line to the master cylinder and the air will be forced out of the master cylinder...no muss, no fuss.
A little trick I learned years ago to beat flat rate. Just thought I'd share it.![]()
What's rwrong with DOT 5? Dot 3 was the one that I really hated!:flag:since DOT 5 sucks,
Ya just taught an old dawg a new trick!it doesnt mix with water. so that bubble of water boils at 212 degrees giving you a vapor lock and the infamous spongy pedal.
dot 3, 4 or 5.1 mix with water but still have a reasonably high boiling point even when water is present. i switched out to motul 600 dot 4. bites like a pitbull!
