Hradek
So we traded the Harley FatBob for the 04 BDM Chopper almost a year ago.
Since then, the Chopper has had one problem after another...
-front shock mount bolt busted
-back shock mount bolt busted
-Clutch cable problems... even after clutch cable was replaced
-replaced base and head gasket
-replaced clutch basket bearing
-did the rebuild kit for the starter sloenoid
-retuned carb
-changed the acc. pump diaphram
After doing all that we still have a few problems with the bike... This is what we need help on!!!!!!
-headlight is stuck on highbeam will not switch to lowbeam... light flashes when trying to switch to lowbeam.
We took headlight apart and replaced bulb... no change. We have noticed that a lot of the BDM's have problems with the EHC and was wondering if this was our problem too? The chopper currently has a Type 2 EHC (176-000003-00 REV J). A guy at ft worth harley gave us a spare EHC... it too is a Type 2 (171-000010-00 REV C). Our question is... if the current EHC is what is causing the headlight problem, can we remove the current EHC and replace it with the spare we were given? OR is there something else causing the headlight problem?
-retuned carb
