francoblay1
The Spaniard
:2thumbs:...............
Never ask me why... Why not? This one is for franco. The OP better close this question and give up the who in the loop is it?
Wow I feel drivin hard and put away wet, thanks for the info.....Basically, yes.
Remember, even though that was headed in the battery of 32 amps? It still had to pass thru the VR and this drops current. It still is being separated in the battery, but say the battery is now the resistor/converter in a way. This is 16v out the battery and the rest is kettle'ing some liquid in a boiled state.
The lights are still in a math kind of rated for, 'uses so much voltage' or it burns out. So no, a 12v bulb cannot last against 16v+ of input or more at it. We are handcuffed to Ohm's laws or the house burns down, the battery blows, you get knocked on your feet you plug something in, etc.
How could you sort of answer your own question I quoted and not buy the volt-reg with the new battery? Right now, your bike is a rolling battery charger, not a balanced kind or start riding as designed. You have a failed part that is causing you to keep buying batteries:
1. Not the Battery = Works for 30 minutes and that means it still worked in that time-frame.
2.. Not the Stator/Rotor = That is working beautifully as it blows bulbs and battery tops.
3. It's the VR = This says it cannot regulate; is it a bridge alright... bridges bommth lanes to boil the batt and is not regulating the voltage ~ BINGO is the WHY!
I think I fryed my EHC. How can I test it??it may be a fuse witch is under left cover on the wire from VR. it is either a fuse or a breaker. on breaker there is, or may be a reset button. Or you may have boiled one too many battery and fried EHC unit with too high voltage for too long time…
hi Seven I'm a new member I own a 06 K9, and have or been having problems with batteries over heating, acid vapor escaping from the breather holes and almost exploiting, I have the VR checked and at that time it was working fine it's when I get hard on the throttle that this happens.Basically, yes.
3. It's the VR = This says it cannot regulate; is it a bridge alright... bridges both lanes to boil the batt and is not regulating the voltage ~ BINGO is the WHY!
I don't think H-D is going to have a regulator for your bike. However, I have a brand new one that I can sell you for $75.00 shipped. Let me know if you are interested.The battery is new I'll swap it out... The regulator is what, 75$? Do ya think HD would carry that part for BDM?
That brings up a stator output rating at 22a or the 32a, look out da way; headlights/taillights buy the dozen I gotta outdue dem dare poker runner uppers wit dare 45a's; eyes gots me a 22a-vo/reg on me 45a stator come sniff. Dat dare is da shitcan sauce marinade. Who brought the bbq is I did. I'ma gonna get me bike close to that watthe fuck are all those lights on for, it's getting hot near my vapor; here comes the lighter for the charcoal...!!!I don't think H-D is going to have a regulator for your bike.
Dam whatever you are smoking needs to stop before you hurt yourself. I thought I was fucked up humThat brings up a stator output rating at 22a or the 32a, look out da way; headlights/taillights buy the dozen I gotta outdue dem dare poker runner uppers wit dare 45a's; eyes gots me a 22a-vo/reg on me 45a stator come sniff. Dat dare is da shitcan sauce marinade. Who brought the bbq is I did. I'ma gonna get me bike close to that watthe fuck are all those lights on for, it's getting hot near my vapor; here comes the lighter for the charcoal...!!!
I see you read Sven post too! He really needs to back off what ever he is consuming!!!!! Just reading it required 4 shots of Taquilla!Dam whatever you are smoking needs to stop before you hurt yourself. I thought I was fucked up hum
Carlos![]()
