onewheelf4
I have been doing some searching around on here and have found a bunch of posts to be very helpful. I'm not a newbie in the motorcycle world, just the Bigdog world. My bike has the low voltage controls, which makes chasing an ignition problem down a tad bit harder. The bike has a no spark condition only every once and a while. You can be going along down the road and the engine will just die. You can fire it up, let it idle for 30 seconds, it will die. Then some other times you can ride the bike all day and have no problems with it at all. when i hold the run button down i notice the light on the EHC will sometimes not light up. there is also a polished aluminum sword and heart device located right next to the battery. the LED on that is also not illuminated. then i checked all of my connections, grounds, etc, turned the key on and off, then magically the LED's illuminated and the bike fired right up. Could i possibly have a loose connection somewhere that i am missing? Is the EHC bad? I'm hoping that one of you guys could point me in the right direction. So far everything has been fine again and i haven't ran into any problems. I am just waiting for the evening that the Mrs and i decide to go out for a ride and the big girl just leaves us stranded on the side of the road. I'm sure that wont lead to any luck at home after that! Jk anyways any help is appreciated, THANKS!!
