I had mine replaced and what I gathered is with the TP Rocker, the geometry was a little off and thus side loading the valves causing uneven forces which in turn created and oblong wear on the guides.
They change out my whole head, springs, valves, roller rockers, guides, everything but the boxes themselve. The TP boxes have held and are holding up good and boxes themselves were not the problem, ti was the rocker and the geometry.
According to what I got from my dealer, it is somewhat common problem on the 05 but not as big as made out to be. Most never have the issue but when it occurs it is usually due to geometry.
Also from what I gathered, orginally BD would just change out the head assembly when it first started up, but got where they wanted to have the dealer check closer after awhile for they were getting too many heads back that had nothing wrong with them. In my case they did a blow down and measured the roundness and found them out of tolerance, thus a change out. The dealer did say that many folks have asked about it and were driven from the noise factor, but many times the noise was jsut due to folks not be familar with the Big Bore Engine and the regular Valve Train noise as well as just needing a adjustment.
So from everything I could gather, it is on some, the geometry is out enough between rockers and valve to create uneven force and thus wear the guides, not on all and not a high precentage, but enough to be possible and when it occurs, BD stepped up while under warrenty. Also that they get allot of new riders concerned about the noise and there is nothing wrong, just riders not used to the new sounds.
