High beam indicator stays on k9 06
k-906
Problems with on off and run bottons, fix that then starter fix that too, now bike still clicks no turn of starter, flashing turn signals and needle up and down.
Need help please
Brew
Sounds like your battery is giving up the ghost, have it load checked. For the high beam, is your high beam on and the headlight wont go to low beam? If so, then that's a default for when the low beam is burnt out. Just saying.
k-906
Check the battery good under a load, when true all the wire connectors to and from the EHC clean them and add dielectric greas.....nothing, I guees is time to send the EHC to Curtis at wil steed for a test.......hopefully is soft ware and not a replacement
k-906
Yes it is....... Had a wire in the wrong please but fixed that, had the starter checked.....all good now....the starter a mean. Still having problems....run power to the starter directly from the battery and it does turn but no brruuumm yet.
I'll keep trying
