Tdubb
Okay, so my electrical problems continue. Last week I washed the bike and afterwards I had no power to the EHC. I was starting disassemble, pull apart connectors,etc and it came back to life. Rode the rest of the day and no issues.
This past week I was getting ready to start doing the dielectric thing and had gotten a couple simple connectors and the battery gave the dreaded click. Had the battery tested and it was fine. Re-installed the battery and all was well. Rode 100 miles Saturday with no issues.
Sunday i decided to take a short ride - around the block so to speak. I came to a stop sign and the bike died - all lights on, etc. I press the run button and no fuel pump sound. I end up tearing things down and then notice all the EHC lights are on. I fiddle with it - disconnect the battery, power on and off and then it comes back to life but the run button will not make the fuel pump energize. I leave to get a trailer and return so I can fire the bike up and ride away with my trailer friend shaking his head.
Okay so I have a few thoughts after reading every word of chapter 13 in the service manual last night and looking at the electrical schematic until my eyes bled.
1. All lights on EHC can indicate a bad ignition switch. If I try real hard I can find a spot between on and off that will cause this condition. This could explain the stalling, but I don't think it explains the others.
2. Could a bad ground cause the all lights on EHC condition and stalling condition?
3. Can a bad VR cause the all lights on EHC and stalling condition?
4. If I can get the run button gremlin to happen again, I will take a volt meter to check continuity when I push the button to rule out the PCB or wire issue.
5. If it's not the run signal I will try and check voltage across the fuel pump motor (+) and motor GND by checking the connector below the fuel tank. I should be getting 5V DC. I need a little help here - this is correct method to troubleshoot an output from the EHC???
Help - bike week is coming!!!
