Little battery troubleshooting help please
Tdubb
I went to start up my bike a little while ago and all the lights came on but all that occurred was "click". I also noticed that the headlight goes out or real dim when I hit start - don't remember if that's normal. I checked the voltage and got 12.6v, tried to start and it, "click"' checked voltage and it was lower at 12.4v. Then a few minutes later I pulled the battery and I got 13.5v unconnected.
I'm thinking to go and have it load tested, but can't do that until tomorrow. The harley dealer does a thorough test that takes about 3 hours or so. However I could just buy a battery tonight, but not sure that battery is shot - sure seems like it though.
Tdubb
Well it wasn't a battery. Harley tested it and it checked okay. The Harley tech said it sounded like a loose ground - maybe on the starter. I hooked everything back up. I checked everything and all was tight. Bike fired right up. This happened once last year, but then I chalked it up that maybe I had not noticed a loose battery terminal. This time I know all was tight. Aggravating...
Tdubb
Yep, absolutely. My headlight never dims which tells me don't waist your time on a load test. Then again, it is easy enough and most places can test your battery when you purchase another including WalMart.
FYI - after some research the service manual states that during starting the EHC turns off the headlight. So it's normal for my 2008 at least.
