Long storage
k9nut
Kind of a dumb question but I have never had to store a bike before. I know some of you have had to deploy and store your bike so give me some tips.
1. Gas tank full with stabilizer or empty?
2. Tires off the ground or on?
3. Any need to do anything with the oil?
4. ETC......
The storage time will be about 12 months. :(
Thank you for any suggestions.
Gary C
CCRainman
K9, I would fill the tank and then add stable to it. Run the bike so the fuel gets into the carb. Then shut down the petcock so there is no more fuel going through. Change all your fluids and if you have a lift, get the bike off the tires. If not inflate the tires to 45-50 psi. This is what I use to do to store my bikes. Don't forget the tender.
K9, you going to South America for a while???? :D
This is right out of our Owners Manual.
I can only add what CC said, "don't forget to put the battery on the tender".
I'd put it up on the jack just to take the pressure off the tires and shocks and throw a soft cover over it.
Enjoy your vacation,
Ray
kickstart
All I can add is, You might want to put a heavy coat of wax on everything. Where and how will it be stored?
PS: Don't take it to Jersey it gets too cold there bring it to my place the garage has AC. :cheers:
k9nut
Thank you all for the help. :cheers: A friend who stores cars drains the gas, but I didn't think I wanted to do that. Thank you ray for reminding me about the owners manual. I didn't get one from Coast with the bike but just downloaded a copy from BDM website. I had some medical expenses so tried to sell it but the only offer I had on the K-9 was $18,000 so I am going to store it in the garage with a cover. I will put it on blocks to get the tires off the floor. At least I will be able to look at it :lol:
I have been storing bikes forever...
For the stabil, here's the best way to use. Add it in AT the gas pump, then put the gas in. That way the rush of filling the tank ensures you mix it well.
You really need to do a complete service as stated below.
Change all the oils, then be sure to restart the bike to wet everything down. Consider fogging the cylinders or at least pull the plugs and spray a shot of lube down the cylinders.
Clean, polish, and wax everything.
Get a lift, or blocks, or a set of scissor jacks to get the weight off the tires. Also, add wood under the tires. However, you don't want to "hang" the suspension, just unload it a bit. So your tires will still be touching that's why I say use wood under the tires.
Put the battery on a tender, NOT A CHARGER, the best bet is a $30 Battery Tender jr. And with this, there really is no need to even pull the battery out.
DO NOT! I REPEAT DO NOT start up the bike during storage, "just to warm it up". That is doing WAY MORE harm!! Especially if its colder out. It creates condensation throught the motor and drivetrain. Condensation causes rust which of coarse is BAD!!
Cover it up.
When it comes to pulling it out, I always change plugs, check tire pressure, and start it up. Check everything over. I tend to run on the "old" new oil for about 500 miles then change it again. That gets all the stabil flushed out and make sure everything is running well and no surprise leaks develop. There is really nothing wrong with the oil its just been sitting. But just in case a gasket or seal took a poo on you over storage (for me winter) you wouldn't have just replaced the oil and be looking at doing it again!!
I'll be making a how to on storage this winter even though that's most of it.
Chopper Dave
SIICK!!!
Cover it up.
K9nut...if you want to know anything about servicing your bike or storage....Gas Man is da Man!! its nice to have good people like that who take time out to help others out with the pic's and stuff.....:2thumbs: everyone here is very helpful .....so that is not a dumb question......I know I have learned alot from everyone here......have a good vaca.....:cheers:
k9nut
Thank you Gas Man. You really go the extra mile in helping others. The only down side is I have to buy so many ink cartridges to print out all your "how To's" :up:
Gary C
TriPPyN
( . )v( . )
So I'm off to Balad in the very near future. 5 months in the sand box... not too bad.
I'll be doing that full service here pretty soon. So the manual says to remove the battery but you're saying if I leave it on the tender I should be good right? You ARE the Gas Man so it must be true.
I have done both. Bottom line is if the battery is good, it will last either way. Just don't have anybody come over and start it/warm it up during its storage... just let it sit.
06Mastiff_shawn
WOW, I guess I should have read this before putting mine in storage. Guess that is what happens when you buy a bike on R&R and have to leave in 2 weeks... But I did store in in my office in the basement next to my bar...
Shawn
WHOA... back up there Sir!
How did you get it down there?
And where are the naughty pics of the wifey ont he bike? YUM YUM
06Mastiff_shawn
Thanks, guys...funny thing is she did most of the work in the basement it was completely unfinished when we got the house in 06 and now she has added 1600sqft to it.
Shawn
