Background ... I replaced the o-rings in my primary because Tranny oil was leaking into the primary. After several adjustments I thought i stopped all leaks around the inner and outer primary. Come to find out while the bike was sitting the last 45 days or so because of winter here in Texas the primary was empty. I did not realize this until after taking off from the house and quickly realizing something was wrong i went back home. GUessing I put about 3 miles on the bike with a dry primary.
After I filled the primary, Now it is having trouble down shifting and occasionally up shifting, but mostly down shifting. It will seem to shift ok at start up, but it does not last long. Could this be because the clutch plates are dry?
