HeyBaylor, can you elaborate a little bit on what is Wetsumping and how can WE fix that? My bike does not start and I hear a lot of gurgling from the overflow hoses? Could my bike be doing that?
MY crankcase was full of oil , I pulled the plugs and spun the starter.
(only do it for about ten seconds then let starter cool for a couple of minutes)
It took several short spins to clear the oil. (keep your battery charged)
I have a slam button , so the ignition was off.
if you don't have a slam , ground the plug wires. ungrounded can cause ignition problems.
there are several ways to clear/clean/repair the checkball valve .
I used a wooden dowel to lightly seat the ball after I removed the spring, and
cleaned the ball, and seat.
hope this helps
