This just for info....
A couple of weeks ago I noticed the RH turn indicator on the clock was flashing in sync with the RPM on the motor. Well, I thought there might be a short on the tach ring as this ring is exposed to moisture as the speedometer fogs up. I asked a few questions in the tech forum and got good answers. Well, today it was too bad weather to take the dinghy out so I spent some time in the shop instead, trying to solve the issue. I started the bike in the dark and sure enough, the front turn signal had flashing as well, just not to the extent the indicator light had. I now figured it had to do with the wiring harness, and with the BDM tester it showed a fault in the wiring harness. I have stocked up on parts for the future and had a new back bone wiring harness laying around and decided to replace the existing one. Sure enough, fixed the problem and besides having to extend a few wires it was a snap to install it.
Again, this post is just something that could be of help to others with the same issue and could be found with a search on here. With this issue (fault in the main harness) there could be any kind of light flashing in sync with the vibration of the bike, as all the light are powered but turned on via ground with a switch in the EHC under the seat.
I dip my valves and pistons in vinny so as to decoke the carbon off the parts and let the apples do their chemical reaction thing. Stuff comes off like putty.
