Removing small scratches
francoblay1
The Spaniard
I have the same problem Franco. If you try it let me know if it works for you.
Dustin,
Just done it, two minutes job.
The Tin-foil & Water trick really is Magic. :up:
Just grab a piece of tin-foil from the kitchen and a glass of water, soak the tin-foil with water and start rubbing it (gently) onto the roughed area.... in two minutes it will be just like new! :whoop:
I wish I had taken a pic of before & after... no need of an after pic as like I said it looks just like new. :2thumbs:
francoblay1
The Spaniard
Dustin,
Well? did it work for you?
