Bike being shipped tomorrow!!
toomanybikes
not enough time 4 riding
Nice bike.
Were the reflectors and down tube sticker gone when you got it or did you have to remove them before taking the pictures?
cdogg556
Went for my first ride on my new bike, it is one bad ass machine! I had a blast riding around town, I went about 40 mi just to check it out, everything worked great, tons of power and looks and sounds great, I let my son take it around the block and now he is hooked, he's gonna end up getting one eventually, the bike is more than I imagined, it is one Bad Ass Big Dog!:whoop::whoop::cheers::cheers:
cdogg556
Aside the obvious exhaust, any other mods done to her, cam maybe? or its all stock?
I pretty sure it's all stock Franco other than it looks like there are led light strips under the tank, rear fender and battery box, I don't see any wires hooked up to them though, looks to me like someone removed the power supply for the system.
francoblay1
The Spaniard
Mine has them leds too... it arrived home all disconnected... I just had to connect it to the battery again. I never use them, but sometimes cruising around the water front in summer its just awesome.... to see the faces of people looking I mean! :D
cdogg556
So franco, are you saying that all I have to do is connent them directly to the battery? I mean though a switch also and they should work? On the ones under the battery box it looks like there is nowhere to connect the power, almost like someone cut off the wire connector, but the others still have a place to connect power too, also I see a connector on the positive bat terminal that has been cut, do these led lights connect to the neg terminal also?:confused:
francoblay1
The Spaniard
Yup, they do connect to the battery (with a 10 amp fuse on the + wire), but... you should have also the switch box somewhere in there, on-off switch plus different sequences switch... its a small (no bigger than 2 x 2 Inches) box. I will find a pic for ya.
Can you make these pics bigger:eek: I think that box also has resisters or capacitors in it to reduce the wattage to the LED's, I'm no sparky but if you hook directly to battery their going to pop. Maybe I'm wrong, but I would do more research before I would juice them up directly to the battery.
cdogg556
Thanks for the pics franco, I looked at the boogie lights website and they sell the kit that is on my bike, I emailed them and hopefully they will set me up :up:
bearman
...I think that box also has resisters or capacitors in it to reduce the wattage to the LED's, ....
Close, but what you're thinking of is reducing voltage. The typical non-high output LED operates at 3.2 volts. They seem to work fine on 12 volts if you run them 3 in a series. Most of these accent lights come in multitudes of 3 for this reason.
I know, I can't help it. It's my OCD kicking in.
And there we have it:2thumbs:
cdogg556
Just got an e mail from Boogie Lights and they are gonna help me figure out what I need to get them back in working order, thanks for the info guys!:2thumbs:
H-fred biker
Mine had the leds too, but I got rid of them, too much Disco :D
And, don´t forget to lift the weights:2thumbs:
