That's what I was going to say. There are a couple guys on here that have that.convert it to an automatic shift
X2 !!! Ask me how I know! :2thumbs:You might be surprised if you just lubricate the clutch cable thoroughly.
Stock 05 and up BDM doesn't have springs it has a diaphragm clutch spring..The removal of a few clutch springs and there are maybe 2 patterns you can get away with. Think of a box or 4 corners and if you have 8 in a circle. So first pattern for finger feel is to run a triangle pattern and that means to remove 3 so there is a triangle pattern of missing springs.
If that's still crankey on the yankey, then try a 4 pattern spring removal and that pattern is a square/box looking corners of empty spring slots. Just think even pressure on the lighter pull pattern.
Upside: Less pull on the joints.
Downside: Possible spinning clutch on hard acceleration.
Upside: You don't have to hunt for some leverage device.
Downside: You didn't stimulate the economy but pulled out a freebee.
And don't take offense to this but see the cashier on your way out.
Well that answers that.Stock 05 and up BDM doesn't have springs it has a diaphragm clutch spring..
Call Curtis in San Diego and he can hook you up. We need to get together for a ride since you are down in this areai have checked with several manufactures and none of them can tell me if it will fit the BIG DOG , matter of fact they only can tell me that they fit Harleys. I do remember that BD did offer something when they were still around.Any suggestions of phone and part numbers.
thanks in advance for ur help
