Front Brake Calipar Piston Removal
Remove the brake pads and stuff a rag in its place and use an air compressor and blow it out using the brake line hole.
When the first one pops out slide it back in and hold it with a screw driver then blow the next one out. After they are all loose, split the caliper in half, and the ones you can't slip out with you fingers, use some snap ring pliers to grab them on the inside of the cup to pull the out.
