K9 new battery dead dog
Tread66
if you are blowing main fuse hook everything up unplug your starter and then put fuse back in and see if it blows. if it does you know it is not the starter. hook everything back up and then unplug your vr and put fuse back in then if it does not blow you know it is the VR. make sure you have a good battery. that is how i found mind and the headlight issue was under the tank. it was just not plugged in. back on the road again until saturday and clutch cable broke, going to replace this weekend.
WTH, clutch cable now, If you wouldn't have bad luck, you wouldn't have any luck at all. Stay with it, its worth it:whoop:
