I just ride it and enjoy. Yes you could have problems, yet the same could happen if you replace it with something else also. Just read some of the issues that have occurred with some of the common replacement from WP, PDM, M-units, RIP, etc.
For the most I personally feel that the vast majority of Stock EHC will work fine if the bike is taken care of, not loaded with a bunch or electronic mods.
All said though, problems can arise at any time with any component, key to lessen is good maintenance, simple pre-ride checks and keep it has designed and be cautious of loading it up with some mods (Lizard lights, HID kits that may not properly designed, hacked alarm systems, etc.) Also cannot over emphasize to keep the battery on a tender if not ridden nearly everyday.
Also when washing, be careful with how the water is sprayed around for our electronics do not like flushing with high pressure nozzles or big stream of water. Still from my experience, sensible washing is not a problem nor rain. Just keep it simple and not over due the hose action.
Enjoy the ride.
I recently bought a 2008 Ridgeback (early built). 1200 miles. I see there are issues with the EHC's and thinking I should just replace it before it stands me. Reading in this Forum that most of the EHC issues were older models.
Should I be worried? Thoughts?
Thanks, Kurt
