08 K-9 EFI BDM EHC delete kit, Help please
D L
Hey,
I'm having some issues with my bike, Anybody have a copy of the installation instructions and wiring schematics you could send me or let me borrow.
I can't find mine right now.
All this info used to be on the BDPP website for easy access, but it's shut down now.
Thanks,
D L
OK, Found my instructions forwiring. Anybody got a PDF copy of the "
"PDM Electrical System master Harness (GEN 2 HCI) for EFI Models
P/N 178-000003-00, Revision C 10/05/2011"
Tks in advance
D L
Hey Jwooky, I have a service manual in a hard copy. Thanks.
Inman, Bikers dream are good people.
I found everything I was looking for tonight at my house. How can I post a PDF on here, I tried but was told PDF file was too large?
Figured I would attach files on here in case someone else is looking for them one day.
D L
178-000107-00_REV_A2.pdf:
Your file of 1.97 MB bytes exceeds the forum's limit of 390.6 KB for this filetype.
178-000003-00_Rev_C.pdf:
Your file of 949.8 KB bytes exceeds the forum's limit of 390.6 KB for this filetype.
Tried to upload from my C: hard drive.
DRBarnhart
Insert title here...
Is there more than one page in each? I could split it up into individual pages if that would help?
Dennis
D L
Dennis
178-000003-00_Rev_C.pdf: is one large page ( Electrical drawing)
178-000107-00_REV_A2.pdf: is several pages
DRBarnhart
Guess you'll either have to find some "cloud" storage for them with a link or just email to folks as needed.
Sorry I can't help...
Dennis
ksmike
Hey,
Thanks,
Just curious, what kind of "issues" are you having?
D L
On deceleration with clutch hand control pulled in, motor will almost die and sometimes the engine does cutoff.
Seems to have started happening when I did the BDM EHC delete rewire kit.
Talked to S&S, bought a Unlocked Fuel Injector computer and had it programmed by S&S and still having issues. Have my bike with Star Racing and they are discussing issues with S&S. Was just trying to give them some wiring diagrams for various parameters to look at.
ksmike
Kind of sounds like a VFI (computer) programming problem..but I wouldn't have thought that would have changed by replacing the EHC. Maybe one of the sensors is unhooked or unplugged? Do you have a check engine lamp on?
Some sensors to check:
Front & Rear Oxygen Sensors
Intake Air Temp Sensor (IAT)
Throttle Position Sensor (TPS)
Manifold Absolute Pressure Sensor (MAP)
Idle Air Control (stepper motor)(IAC)...???
Engine Temp Sensor (ETS)
:up:
D L
:up:
Did the EHC rewire swap and the noticed a jake brake sound when I had the clutch pulled in coming to a stop, almost like a sputtering/big truck jake brake sound and sometimes engine would cut off. Checked all sensors, no problem. Don't remember hearing that sound when bike was all stock? Talked to S&S they suggested trying a unlocked S&S EFI computer that they could re-pogram. Did that, still did same thing, tried to get it tuned a few times and still had same problems but not as frequent. So here I am today trying to fix/solve the problem once more for good. lol.
No check engine light, It's been going on for years. lol I've just been dealing with it.
My friend at Star Racing thinks he has it narrowed down to the Speed Sensor maybe not feeding correct data back to S&S EFI Computer.
Tom Hampton at S&S Cycle and my friend Derrell at Star Racing are working on correcting the issue. I'm hoping providing them with an electrical wiring diagram would help them figure it out. Good thing I had the PDF files saved on my home computers hard drive.
Thanks,
ksmike
Have you had anyone tune the ECU (VFI) on a dyno? It sounds a lot like the issue I had with my bike once, after I had Gateway Big Dog tune it. It was just the way they set up the closed throttle program to cut all fuel when the throttle was closed. It made the bike sound funny on deceleration and hesitate when the throttle was opened back up....:confused: They way they had the program set up it felt like you turned the key off when the throttle was chopped slowing down.
They was able to fix the program to make it work properly.
D L
I'll mention it to Derrell. tks
