S&S Pushrod Adjustment Guide
1. Home he dose snot give two sheets about yo stink inn lick inn crack in the theory.
2. Buckle my shoe, you forgot to start with 1.
I'm going to sneak up on your abstract and give you the angle of the dangle get ready, set?
3. Whathell are you doing? Well I was just pointing out how you have these techo no or tech you do some shitforbang parts is as same as the parts is parts theory.
4. Ass write. I rather write you a little note about this very theory is think about this. I have a pounding in the engine.
a. I have a spring that wants to pull my nuts right off me.
b. I have cam that lifts fast and drop my trousers just like that was my balls were attached when that happened.
c. I have a short [turtle] neck being the afterbirth that thing was trying to pull on.
5. Doesn't that sound like valve sink? Why, if you say it like that, yes I can see a valve sinking during its life cycle like follow it you mean?
6. Y for yes, that's what I would do. You don't mean place a hose in the spark plug and blow in it until I have valve lift? Y, yes again.
7. So you mean I should do this both ways is follow that lead on the url? Shithefuk I would. You mean, follow the valve drop? I sink that's what you said, but I better read this again.
8. No you don't. Step out of the way. Home he does not need a hose me feel. Oh don't tell me you have magic turtle hands running over rocksandshit you can set a valve without a feeler gauge and this is the same thing.
9. You know, you are a fuk'inn wize guy. Yeah, but my shit up against shore shit to shore, I shore can make a wave, gimme a magnet. :roll:
MMmmmmmmmmmmmmmm, square waves. ECU see watt eye sea? Flat for Flat, now tighten nut?
