Here is a pic of the PDMLook under your seat.
If you see a little fuse panel by the battery that says "PDM" on it then you have the BD PDM system.
Don't see that? Then look down around the sides of the battery. See a little rectangular box with 2 huge connectors on it? Then you have the BD EHC.
Don't see either one of the above? Then you have something other than the BD EHC or PDM.
The Adjure is a plug & play. The only issue with the adjure is the high low beam indicator is backwards after the install and I have not figured out a way to fix it yet.So I take it that the Adjure LED unit should fit in my K9 housing but is it just direct plug in or would it also require the interrupt harness like the h4 led bulb since I still have the EHC unit ???
Brother, you are NOT allowed to sleep!!! get in there and sort it out.... Do It Now!!!Unfortunately just sleeping.......:bang:
Maybe the bulb is in upside down.:roll:....the high low beam indicator is backwards.....
