Sounds like belt slipping
Kmackmer
I just bought a 05 big dog bulldog from orginal owner. Has 2900 miles on it. When I gas it hard it sounds like the primary is slipping on the left side. Everything is right and looks new on the chain and back belt. I adjusted the clutch to factory specs. Any ideas? Could it be the clutch plates dry for
It setting up so long? Any help would be appreciated! Thanks, Keith
Kmackmer
Should I pull the clutches out and soak them in oil over night then reassemble? It just started making noise when I pull the clutch lever
Eventually it will stop doing it. I rather ride it than tear it down, swap plates around when it will go away quietly as it heats up, slips as you shift, etc.
