That´s what I use too. Also in the cables! :2thumbs:Here's a great lube to use on the heim joints:
Thanks for checking that for me Franco and I know what you mean about the glasses. lolJust went downstairs to have a look at mine.... the bolts need to be tight (obviously), not sure about a washer... forgot my glasses, lol.
I would think your heim joint ball is very dry (and maybe a bit of rust in it).... I would soak it with penetrating oil till it frees up. then keep it lubed regularly.
When was last time you lubed it???
what is a cleve block? I adjusted my shift cable at the rod adjustment unit. cracked the retaining nut and tightened the allen screw and rod until the lever moved to a tightened position. all this was done after the cable was backed off on the down tube. now my bike was doing fine after re assembly and the shifting became so tight it would not go past 2nd. when I got home the shift pedal was grinding. WD 40 helped for a second giving me previous spring back but after the bike was running and got hot it reverted to the tightness. did my clutch cable adjusting do too much?The shift linkage absolutely has an effect on shifting. Although that shouldn't have changed just from installing a clutch cable. Forget about lining it up with your brake pedal. Take the shift linkage loose at the front.(3/16" allen on the front 1/2" hex nylock on the back) Make a mark with a sharpie in the middle of your shifter. Move it all the way to the front of it's travel, and make a mark on the cleve block(for lack of a better term) with a sharpie, then move it all the way to the back and make another mark. Loosen up the jams on the linkage and line it up right in middle of the two marks. C.A.Jones V-Twin | Custom Builds, Parts & Service
