Happy R.I.P. Kit Customers
Listen to me folks.
If you have not changed your control harnesses, that is the harnesses that the A and B backbone harnesses plug into, then this kit is truly Plug & Play. You remove your existing EHC and both harnesses connected to it back to the JST connectors they are plugged into. Install the new EHC mount, install the new R.I.P. module to it, pull your harnesses into place, plug everything back in according to labels attached to the R.I.P. kit.
tomtang I wish you had contacted me first before chopping your harness up. If you have trouble pulling your harness through the backbone it is far easier to pick up a small bottle of electrical line lube, run several coat hangers through the backbone and pull each connector through gradually one in front of the other.
Tomtang aka Reptilejim
Greg, I have the big radius, different air cleaner, different jets and 626 redshift cam for two up riding. These are my mods. It's pouring down rain here. I haven't rode the bike yet but when I do I'll let you know. I have it set on #3
francoblay1
The Spaniard
Mine dosent look like that either, mine was truely plug and play. I think his that pic is because he had the wire plus kit before the RIP kit I have pics of mine just cant get them to load I would email them to some one if they want to post them for me.
I will post your pics if you like. :up:
