clutch CABLE replacement problems?
Billy the kid
Marc, I think you have the adjustment right. Try starting the bike and trying it, FYI with bike not running and put in gear with the clutch lever pulled in bike will not roll, hope that helps.
mml03102
Thanks for all your advise but I believe Billy the kid solved the problem , although I tried starting it in gear it was lunging forward as Billy said I started it in neutral and put it in gear , the clutch was engaging some but it was crawling so I tightened it somemore and it seems fine now, Im going to put the exhaust back on and take it out for a ride and see what happens , I hope that was it, thanks again
... although I tried starting it in gear it was lunging forward...
The wave plate has to be flat [if applies] = If too coned the plates touch and cause drag.
The wave plate, the pack is correct, but the ramp screw out begins to touch more up the ramp which does not throw the pressure plate farther away from the plates = Drag or creeps in gear/grinds into gear from N/hard to stab back to N.
Therefore, no matter how you take up the slack, you are not breaking plates so they are apart a touch farther so they do not drag/cause creep/hard to find N.
Ramplight is what you fight :D
Even if I give the smallest of details you still do not see it. And I can see it from here. :whoop:
mml03102
Nothing is dragging or walking anymore and Im able to pop it into neutral no problem but thank you fro the criticism Sven :hi:
05chop
its all good marc we all learned something hope it works out.sven every time you post i learn something too would it be fair for me to assume that you used to be a mechanical engineer or a damn good instructor?no spell check sorry
Neither. Just a self taught motorcycle mechanic. I only wish your assumption was right for either one. Thanks for that thought, 05chop. :cheers: We ever come across-country travels, I'll buy all night. To me that quote is a written diploma I wish I could hang it in the garage somewhere.
Utopiapga
Ditto!! Try starting the bike it does not always work right without starting the bike. Sounds silly but trust me on this!
mml03102
That doesn't make sense to me either but starting the bike did the trick , I been out riding all day today and all is fine , thanks again! :2thumbs:
