Tdubb
Well I hope I don't have any more issues with my bike before June 2nd. Don't know what I'll do without my internet mechanic!:up:I'll be back in the States June 2nd...
Have a great trip!
Big thanks to Andrew. My transmission is the best it has ever been. Fast turn around and answered all my questions.
The usual bearings were worn, causing his problems. So he now has the updated main shaft, all new SKF bearings and shift paw assembly as well. :2thumbs:
Andrew, you da Man!!! what was wrong with it then?
Rebuilds start at $385 + shipping. If main shaft is needed along with any other parts, price will be more. In a lot of cases the shift paw is worn and needs replacing. The original one is nothing more than normal steel, so it does wear out quick. I'm actually in the process of having some laser cut out using a higher grade steel, making it much stronger and will last a lot longer.what was the price? if i may ask.
