Need help testing my thunder heart ignition module
rottie1
Just finished putting the RIp kit in my 05 Mastiff went pretty smooth everything seems to be working except for my ignition module. The lights on it arent coming on and I dont have any spark. Any ideas and info on how to test it would be of great help.
Brew
Check the power wires that plug into the module. That would tell you if your getting power to the module. If you have power up to the module chances are your module is bad. If you have no power going to the module then there's an issue with the harness. Plug should have a red, black and green wire. Turn the key on and push run and check with a meter across the red and black pins using DC setting on the meter , you should have 12 volts DC.
rottie1
Thanks I will try it soon as I get home Im at work right now I think on the new RIP kit you dont have to push the run button before hitting the start button
Brew
You might want to try and start it by using the run button. I thought the WP was the only aftermarket unit that didn't use the run button, but I could be wrong. :D
rottie1
I guess I miss read the instructions hit the run button and what do you know ignition module lights up and bike fires right up
