I agree with tach01. Compression will cause a no to poor idle of say one cylinder is hung up. During a ride, this would hiss at every compression stroke as the piston pushes the air out of that release mechanism.
1. Poor miss while riding = Not compression
2. Poor miss while riding = Not fuel flow
3. Poor miss while riding = Possible spark.
Why?
A. Comp = Bike starts and idles is my assumption.
B. Fuel = Bike starts and idles is my assumption that the fuel jets are clean or no idle if either jet was clogged and/or partially clogged.
C. Spark = Bike has a miss while riding, yes?
D. Variable = It's either a plug wire, a spark plug, a lose battery cable, or if cutting out electrically, then this key fob business of a key switch.
Why spark? Because it starts and runs. Because you say the carb is clean, so it ran fine before, correct? No jetting to solve if it was running good then, but now this new miss. So, back to spark someplace is the guess, we eliminate the other 2 variables out of the way.
Make sense?
This does make sense, Sven... thanks for this. I missed this post before my last reply. I don't think the bike was missing actually... sort of "running rough" and unresponsive when I blip the throttle. I realize this is a crappy description, but I don't know how to describe it any better. I think I may be having two problems here.
The bike is pretty new to me, and I haven't had a lot of time riding it without problems, so I do not have a good baseline. I have been wrestling with a clutch slippage problem for quite some time... Andrew posted about my attempts... ( he's been helping me with a lot of advice and infromation) He posted about a forum guy who spent loads of cash and got screwed by bad mechanics...that was my sorry ass.
Carl's Speed Shop supposedly re-jetted the bike for the 2-2 big radius (previous owner didn't re-jet from stock), but I don't know if they did anything at all... it was popping a lot on decel and what not, but it ran strong when I test road it at purchase time in Ohio (Im in Fl now). Carl's couldn't seem to get the clutch to not slip, and after many other issues with them I brought it to another guy. All this time, I'd only ride it for short runs testing the clutch... it never stayed without slipping for long... 20-40 mile stints. The new guy (Chopper Design) sent my clutch and trans to baker. After a rebuilt trans and and a rebuilt clutch, I thought that was all behind me. I had one good day on it where it was running quite well, but I really didn't whack the throttle the whole time. Then, after having a beer at a local bar, I came out to start the bike and the clutch was totally slack (this after 100 miles of it working flawlessly). There were no signs even toward the end of my ride that the clutch was failing. I brought the bike out to the guy who I worked with last... we found that the clutch hub nut had backed off. He supposedly cleaned the main shaft, red loctited it and torqued it to 150 ft lbs. Needless to say... I'm starting to feel like getting more involved with the bike personally... not only to save A LOT of money, but also I want to get a more visceral understanding of this bike.... cause I love the shit out of it (even though it has been a bitch), and I want to know how it works and for it to run correctly.
When I road the bike out from Chopper Design after the hub nut issue, I noticed a lot of vibration... more then usual... especially at speeds above 83 or so. I also noticed that it seems to run rough at around 300 rpm or 70 miles per hourish. I haven't been able to ride it all day since then... only to and from work really (20 minute ride on back roads), due to schedule and weather. I've probably done around 100-130 miles in short trips. I thought something might have been done improperly with the clutch at first, but the clutch seems to be working perfectly... no slip, no creep, and I can find neutral easily. Then, I started thinking I was having a venting issue because I heard that popping sound once, another time I shut the petcock off and heard a moan from the carb...also found a drop of what I thought was gas on the cam cover (now I'm wondering if it was from condensation on the carb body).
ALso, it would die immediately if I didn't have the petcock on when I started it a couple of times... instead of a sputter, then dyeing like usual.
The very weird thing is that so far the issue seems intermittent...just when I think the problem is sticking around, the next time I ride it, the vibration level seems normal, and there really isn't any of this "rough running". I am thinking that my lack of responsiveness might be remedied with some accelerator pump adjustment, and maybe the "rough running" is actually more of a mental issue :loony: ...
maybe the lack of responsiveness combined with the excess vibration was convincing me that the two symptoms were one problem. Like I said... the weird thing is that it doesn't always happen. I just road it today, and although ti doesn't seem particularly responsive, the vibration felt normal at 70 mph and below... I didn't have an opportunity to get up to 90 though.
