Rally
When riding my 2005 BD Chopper I hear a high pitched noise when riding and when accelerating coming from the right side of bike. If I pull in the clutch and coast the noise goes away. If I hit a bump in the road under power I hear that noise a bit louder than when riding along under power.
The noise is not coming from the exhaust pipes VH Big Radius nor do I have any exhaust leaks.
I've changed to the 250x40x18 Avon rear tire which is really really close to the belt on the right side. I can see a small space/gap between tire and belt and no rubbing marks on inside of belt or edge of tire. The original rear wheel bearings are still in with 14k miles on the bike. The rear tire is aligned straight and has been checked.
The stock tire size is 240x40x18 but I went up in size when new a rear tire was needed. Their is a bigger gap between this tire and the belt also.
I'm wondering if because of vibration and the very small gap between tire edge and belt it hits the tire making this noise when riding?
This weekend I was caught in some heavy rain coming from the FL Keys and the noise seemed to be louder in the rain and wet road. I've looked and looked all around to find somthing indicating where this noise is coming from but no luck so far.
When I change the rear wheel again I will go with the stock size 240x40x18 Avon and have new rear bearings installed also.
Anyone have any ideas/clues as to what is causing this noise?
Thanks in advance
let the jokes begin
Thanks in advance
let the jokes begin
