Open Belt Drives and the Clutch Hub Nut
zenBD
Can anyone tell me if the baker open belt drive set up or any other open belt primary eliminates the dreaded clutch hub nut issue via an alternate clutch set up?
Sent from my iPad using Tapatalk HD
Bowhunter
You still have a 'main' nut holding the clutch basket and engine drive pulley in place. So you could still have the nut potentially come loose, but you would be able to visually SEE that something is wrong.
zenBD
Good point! Easy access if it does as well. PKNOWLES ... What brand is yours?
zenBD
Good to know... Thanks. Great looking piece too.
