JWScarab
So today I go out for a cruise. Come to an intersection a HUNDREDS of bikes turning, so I ask the guy that has the intersection blocked - Can I join you? "Sure"!!
Off I go, happy as a dog with no fleas, and we run down back roads etc. then thru this urban area, slow, real low speeds, then thru a subdivision to a park. Next stop - BAM. Dead dog. I start it back up, go to next stop - dies again. I feel a lot of heat under my right leg. I start it and give it a little throttle and it runs great till I let off throttle to idle and it dies! I think it was hot.
It is hot today, about 90*. So I break away from the pack and stray to the local watering hole. Dog is resting for 45 minutes. Once I get back on it, no issues. I cruise home, 60mph, get home, no issues!
Soooo. 3 things changed since my last ride.
1) I just rode in hot weather stop and go - a new for me and the dog (I just got it).
2) I just changed the plugs. Put in brand new Champion RN12YC's at 0.040". The old plugs I pulled out were NGK BPR5ES.
3) Just changed my oil and used Mobile 1 20W50 and K&N 170C filter. Oil is still full (3 qts - 1.5" below tank neck).
Questions:
Is it normal behavior for a dog get hot and die?? Why would this be??
Should I invest in an oil temp gauge or is this a gimmick accessory?? I like simple, but I like meaningful data more!!
Are other plugs going to be better than the Champions recommended buy the service manual?
Any thoughts from you experts greatly appreciated!!
Questions:
