License Plate LED
So my LED board has only two bulbs that light up. I found that one of the wires was pinched since the wife was not fully in the cut out of the mount. If it's just the bulbs I understand how to replace them. If wire needs to be replaced where can I get and plug end of the wire for our harnesses, or is it easy enough to reuse the plug end. I suck at electrical, but have a friend who can definitely do it with no issues. Hope this doesn't sound stupid, just want it done right.
They are JST connectors. I believe WSW may have them?
If its just a pinched wire just have your friend splice in a new piece. The pins are relatively easy to pull from the plug case you just have to be patient and careful
Brew
Patience is the key word :D I played with these connectors for hours trying to de-pin them. They can be a bitch at times...:roll:
Misfit
Jewelers flat screw drivers are what I use when try'n to de-pin connectors.
But once that part is done its remedial.
Good luck bro.
