BigDogBro1
Made in the USA
Rebuilding the clutch on one of the 2007 Bulldogs.
It is the soft-pull 9 plate clutch pack with the Soft Pull ball ramps.
Are there any other different parts between the 9-plate and 12-plate systems other the the number of plates in the pack and the long sloped ball ramps?
Are the stock 12-plate disc/plates a different thickness?
is the pressure plate the same for both?
Does a friction disc run directly against the aluminum pressure plate face or is there a steel disc against the pressure plate?
