JustDennis
I just got a 2002 Pitbull and love it. I have been going thru fixing a lot of little things. Horn didn't work - broken wire. Headlight didn't work - broken bulb and adjure light wasn't in tight. Speedo didn't work - shorted wire. Battery was dead when I got it home - put on trickle charge - starts and runs well (well little rich at idle but will get to that next)
So now I am checking the charging system. New battery checks at 13.46 volts after taking off charger and waiting 5 minutes. Turn on switch drops to about 13.2 with low beam on. Starts right up then stays around 12.8. When I raise the rpms the voltage stays the same.
After searching on here I started looking for the circuit breaker. Sine this is my first BD am not sure what I am looking for. Voltage regulator is pn #55120. Where is the circuit breaker? Driving me crazy...
Ride Safe,
JustDennis
Ride Safe,
JustDennis
