KaptinAmerika
That's because you hardly ride your chop......:roll::iagree:
My Yuasa 310 cc is still going like new on its third year.
$90 and Free Shipping Amazon.com: Yuasa YUAM620BH YTX20HL-BS Battery: Automotive :2thumbs:
I was going to say.. you should be faster shipping parts... but... I cannot say that.... your right.......... I need more saddle time!!! :2thumbs:That's because you hardly ride your chop......:roll:
:iagree: :2thumbs:First, as said a thousand times here, DO NOT jumpstart with car engine running, specially if you like your EHC.
If a fully charged car battery has hard time to crank your engine and release valves are working, I think it's safe bet to say there is something wrong with starter, or wires are loose somewhere. And that is the reason for battery to start melting.
How is the big cable between solenoid and starter? Has insulation melted and bare cable is touching solenoid or starter? I suppose you have checked the wires on battery terminals are tight...
If all the wires are good, send the starter to Kaptain for total rebuild. Hell, it's a good idea anyway!
Tapio
Electronics are sealedWhen I press the slam button, the engine would stall for a second before turning over. Sometimes just hang there for a up to 5 seconds. I was told this is what was breaking my jackshaft. My compression releases are working correctly. Ive tested them by laying my finger on each one when I would press the slam button. Someone told me to inject PB penetrating lube into each of the bubbles encasing the C/R's. Wouldnt the liquid damage the electronics of the units?
Your using a slam button? are you hitting the run, then start button at the same time as the slam to engage the compression releases?When I press the slam button, the engine would stall for a second before turning over. Sometimes just hang there for a up to 5 seconds. I was told this is what was breaking my jackshaft. My compression releases are working correctly. Ive tested them by laying my finger on each one when I would press the slam button. Someone told me to inject PB penetrating lube into each of the bubbles encasing the C/R's. Wouldnt the liquid damage the electronics of the units?
yeahhhh....... I was thinking about that b4... but I refrained myself of asking........Your using a slam button? are you hitting the run, then start button at the same time as the slam to engage the compression releases?
Thanks for the update... keep us posted. :2thumbs:Srodden, thanks for the direction and pics. Ive replaced the solenoid connections and cleaned out the area. But Ive never removed the body of the starter. Ill have ot do that and see what crap I find inside. Ill ck for the primary vent. This site is such a plethora of information.
BB & francoblay1, my Start button has died. So I do the key, hit the Run, then the slam button. I wired my C/R's the solenoid. I found the directions on here somewhere. The C/R's are working, I check them almost every start.
don't do it!I had searched on the forum site, but go figure, as soon as I posted I did another search on google and it pulled up http://www.bigdogbiker.com/forums/help-wanted/17622-2008-pitbull-battery-removal.html
There are 4 screws - two towards the front and two towards the back under the black plastic inserts. The strap is solid steel (covered with a thin rubber band) so no stretching possible. One side of the band ties via the lug nut as shown in the post above.
Now to find a good inexpensive battery...![]()
I believe it. I just checked the battery on my 2008 softail and it's the original one. Bike starts up fine and the lights don't dim at idle. I usually replace my batteries every year with a Walmart special and have had no problems what so ever. I think I'll leave this one in just to see how long it lasts. Of course you know it will die at 2am on a sat night in front of a bar with the local cop across the street....Believe me or not, I just pulled that battery out and it's a Harley battery # 65989-97A, with a confirmed date on the side of 2007. He stores this bike at my shop, and started it up myself the first part of Dec. I told him that while we are putting some money into it this winter, we might as well change the battery because it was so old, not because it wasn't working.
Why is everybody else having so much battery trouble when their keeping them on the tinder all the time?
