I changed battery and know will not start and horn stays on
chrishinpgh
I put in a new battery from battery plus and now the bike with not start, as soon as I turn the key on the horn go on and will not stop . Are there any trouble codes I should look for. I will appreciate any help or advice.
chrishinpgh
Thanks for the info, I will check . Is the horn supposed to go off when the battery is low when you try to start the bike
Nukeranger
Nukeranger
Load test your battery from Battery Plus. What battery did you get and how many cca does it have? You'll be surprised but it is very likely not up to snuff.
Does the horn beep or stay on. If it stays on as soon as you turn the key on check for a grounded wire somewhere. Make sure all positive wires and ground wires are hooked up correctly and make sure none of the hot wires are grounding anywhere.
chrishinpgh
Thanks for all the hep guys. It was the new battery. I took it back and got my old battery back. And the bike started. I still need to get a new battery . What are you guys running. Brand and part number also kaptinamerika do you sell batterys....and if you guys are every in pittsburgh I owe you a beer
by any chance was the battery you returned an Interstate???
chrishinpgh
No it was from a store called battery plus they are specialist in battery lol sold me a bad battery and did not want to take it back .. the one that was in the bike was a interstate pwc battery. It lasted 3 years . So now I dont know what battery to get.
Brew
Harley batteries in all my scoots, part number is: 65989-97C
chacha
Chaff Your EHC!!
Hard to go wrong with a stock HD AGM battery -- you can buy 2-3 of those for the cost of a "high-tech" battery.
chrishinpgh
So I got a new battery from harley. Bike started right up, then the next day same thing tried to start the bike . And the horn stayed on and the bike would not start. I played around for a few hours and the bike would start . Next thing you know horn would stay on and no start. Should I get a new ehc. Or I am think of redoing the hole bike to take harley switches and do a thunder heart. Ehc what do you guys thing
Mine was acting very similar... turn the key on and no lights at all then after about 5 seconds the horn started blowing none stop and the right front turn signal was flashing. Took it to the shop and they told me the battery didn't have enough voltage so they charged it and it was fine.
They also told me that these bikes require a min.of 12.6 volts to operate the module????
not sure about the voltage but so far so good after they charged it. Im sure it being sub zero freezing here still doesn't help the batery !!!!!
Check your charging system... :hi:
Dennis
As Dennis said check the volts when bike is running, put battery on a tender to charge it up. Should be 14.4-14.6v when running
Or you got something draining the battery as the bike sits.
