will mastiff gas tank fit k9
knine08
I have 08 k9 I wanted to put a bigger and more rounded teardrop style gas tank on it. will the the mastiff work or is there a better tank to use?
aspen874
I don't think anyone here has tried it, that may be the reason no one responds.
knine08
was hoping it was tried so I wouldnt have to fabricate. it does not need to be the mastiff tank, just a tank similar that would fit k9 mounts.
if not, what might be closet type of tank with minimum fabrication
You originally asked if the Mastiff tank would work:confused:
Do you have a Big Dog manual? you can see the different mounts in there.
knine08
I need to clarify that I do not have the EFI, it is a G-carb. my bad
looks like the mounting is different anyway.
