Supertrapp baffles
Srodden
Anyone know if the baffles can be completely pulled out of the original supertrapp exhaust ? Just like the Vance and Hines 2 into 2.
non removable. some have drilled several holes up the end with a 12" bit to get through the baffle but pretty sure they are welded in place.
bohussound
Yes they can be pulled out if you cut them off at the back. But there is nothing you can do more than make a large hole in each end. Even then the sound only gets a little higher so it's not worth doing it since you're gonna end up changing them anyway.
Srodden
Ya your probably right I like the looks of the supertrapp but not the sound. On my 05 I put V&H 2 into 2 took baffles out and installed thunder monster baffles love em !
aspen874
I did the same, V&H 2 into 2 with Thunder Monster baffles, great sound :cheers:
