Not sure how to correct the actual list, so someone will have to help. But here are some of the ones that should be changed...
-Belt tensioner 40 ft-lbs 272 Red ( ?? this is
Wolf? )
-Brake rotor mount bolt 50 ft lbs 272 Red ( 25 ft lbs )
-Cam nut 60 ft lbs 243 Blue ( Cam nut?
-Carb to manifold bolts 35-40 in-lbs 222 Purple ( 10-32 EFI) (3/8" bolts, Carburetor 18-20 ft lbs, Blue )
-Cylinder head bolts 8 ft-lbs,18 ft-lbs then 90 degrees Engine Oil (10,20, final 40 ft lbs)
-Front axle pinch bolts 12 ft lbs 243 Blue ( 9 ft lbs)
-Inner primary bolts 15-18 ft-lbs 243 Blue ( 19 ft lbs )
-Inspection cover bolts 9 ft lbs 243 Blue ( 4-6 ft lbs )
-Motor mount bolts 50-60 ft-lbs 243 Blue ( Red )
-Neutral switch 10-15 ft-lbs 243 Blue ( Thread sealant )
-Oil pump assembly bolts 100 in-lbs 243 Blue ( 80 in lbs rotating, 100 in lbs final )
-Oil pump mounting bolts 15-18 ft-lbs 243 Blue ( ??
-Pinion Bolt 35 ft-lbs Engine Oil ( Pinion Nut? 50 ft lbs, RED loctite )
-Rear axle 55-65 ft lbs Antiseize on Rod ( 65-70 ft lbs )
-Rear fender strut bolts 25 ft lbs 243 Blue ( 35 ft lbs, RED loctite )
-Reed valve screws 10-20 in-lbs 222 Purple ( ??
-Rob Bolt 23 ft-lbs, !45 degrees Engine Oil (??
Rob bolt? )
-Rocker arm nuts 30 ft-lbs 272 Red ( Bolts? 20 ft lbs, Blue Loctite )
-Rocker Box 5/16” 15-18 ft-lbs 243 Blue ( 18-20 ft lbs )
-Transmission drain plug 7-9 ft-lbs teflon tape ( 6-7 ft lbs )
-Transmission Drive side Pulley nut 50 ft-lbs + 40 degrees 272 Red ( 80 ft lbs )
-Transmission main / clutch hub shaft nut 80 ft-lbs 272 Red (100-120 ft lbs)
-Triple tree pinch 16 ft-lbs 243 Blue ( 10 ft lbs )
-Upper engine mount to cylinder 35-40 ft lbs 243 Blue ( RED loctite )
-Upper engine mount to frame 45 ft lbs 243 Blue ( RED Loctite )
