Splitlog
Ok, I have a Wire Plus and had no issues for over 5 years.
Now at random times its like you turn the key off. i mean nothing works.
So far recycle the ignition and it will start back up with no problem.
I pulled everything loose while the key was on and started tracing wires
to check connections. Pulled and messed with everything. Unplugged and
plugged back in and could not duplicate issue.
THEN
when i was not even touching the dang thing the power shut off and then came back on imdediately.
Messed with stuff again and could not get it to happen..
QUESTION:
so if it is one of the 2 modules going bad with the Wire Plus, which one is it???
the POWER module or the SWITCH module?
Thanks
THEN
QUESTION:
Thanks
