whompditty
Hey All,
Ok, I have been sniffing through all of the threads and found quite a few carb threads out there, lots of info, but am hoping some folks can document actual results that fixed the dreaded carb cough.
I have a 2007 K-9 with a 117 S&S (it's black so it's the fastest one) with 1800 miles. ( I am the new owner)
Here is the scenario - lots of power and great throttle response. But...
Going down the highway at 70-75- running 6th gear at 2500 rpm. Every so often I get a nasty carb cough/sneeze. Feels like the bike lurkes a bit. Also, about 40% of the time it back fires when gas up and start the bike.
I have stock pipes, stock carb, stock air cleaner. I live in Raleigh, NC which is 350 feet above sea level.
Everything on the bike was stock so I am assuming so are the jets. I don't know where the ORIGINAL owner had the bike as I bought it from the dealership he traded it in in at. So if you are counting, technically, I am the third owner.
Anyway, I have seen quite a few "try this" responses, but has anyone found the true fix to the carb cough at highway speeds?
Since I have stock jets, what should be the first thing I do, increase the main or play with the accelerator pump?
Thanks again for any responses.
