Need fuel filter
Tdubb
Did the victory filters go in the tank and in the fuel line? Did you find out what the micron rating for the filters are? Thanks Tom
I disassembled the Victory setup and used one of the filters. It was identical. Per Andrew the filter has a 30 micron rating.
Tdubb
any pics?
This is a photo from The Vic Shop website. I got the filters and hose assembly. I just cut off the hoses. I now have a spare filter. The filters were identical to ours. I didn't trust the Walbro part number 125-192. No one had one in stock or photos. So I didn't know what I would get. I knew these at least we're meant for a Fuel injected v-twin. Also Victory is second to none in quality and if those filters are good enough for them they're good enough for me.
ground pounder
Looks just like the walbro filter which is a lot cheaper. $8.23 from outdoor distributers and 15 microns, TDubb.
KCrider78
I'm currently searching for the seals to put the lines through the tank, I've posted a diagram and numbers in technical forum under the heading fuel pump assembly of exactly what I need but there isn't any actual part numbers and I'm at a loss. Any help would be greatly appreciated. Thanks.
KCrider78
I did the same thing, works great but I tore a seal so gas is leaking from the tank, any info on the seals I need would be great, I posted specifics in the tech forum under thread heading fuel pump assembly
