Starter tearing up the Starter Ring Gear
Starter on my 07 K9 is tearing up the Starter Ring Gear and finding some shavings in the primary. The starter makes a load clunk once in awhile, its not all the time. I've put about 1,500 miles on it as it's just off and on. However after noticing the shavings have become a bit more concerned.
Anyone have any suggestions?
chacha
Chaff Your EHC!!
Things to check;
- play in the shaft that holds the pinion gear
- alignment of the pinion and the starter ring gear (while the outer primary case is off)
- starter body alignment to the primary housing (a loose starter mounting bolt can cause this)
Thanks guys...I haven't opened it up to take a look yet. Bought a house a few months ago and lift hasn't made its way to the new house yet. Hopefully finish my garage next weekend and get settled with all my tools.
Diesel Dan
Send that starter 2 Curtis.....he will fix it up.....as others mentioned..........check the starter housing......look for any cracks!
pknowles
RETIRED
Eric, obviously you don't have your priorities in the correct order, tools always first:D
I noticed my Pit had some wear on the ring so I took it off and flipped it around. Nearly new surface for the starter gear now. Just my poor ass fix.....and 2¢.
H just wanted to say thanks for the v&h pipes, really liking them . Need to do an alignment and the fix the short in the headlight! Then ride it . The bbc sled is my favorite one
Yea - Well I was previously renting and I still have the garage and could only find someone to rent the apt and didn't want the garage. So since I'm still paying for the garage the tools were last.
