SmartLink III
DRBarnhart
Insert title here...
Been looking for that for a while... Although, now that BDM is defunct maybe one of the "ex" mechanics willl hook us up? :rolleyes:
Dennis
Nukeranger
Nukeranger
I sure hope so. It can't be proprietary since BDM doesn't exist. I mean, they don't own any property anymore.
11bsoldier
my father in law was trying to help me with some issues on my bike, he ended up getting the software for something like 14 bucks, it took some digging around to find it though and then some more time to figure out which version. ill see if i can get that website for you guys, the company we got it from is open monday through saturday so ill try to get up before then.
11bsoldier
so i plugged my software loaded laptop into my bigdog... to my surprise this is not like my other bike, this is more of a code throwing software i dont know if this is what you guys were looking for or nor but i was able to see everything on the bike but they are like digital code and there is alot of them so basically i have two windows open on my cpu one from the motorcycle showing all the codes, and the other is like an index of what they all mean, i havent figured it out quite yet, like i said dont know if this is what yall are looking for but its what i have
Nukeranger
Nukeranger
It is called "Smart EHC software" and screenshots are shown in the Service Manual. The Main Form will display the VIN number, Fault Circuits 1 through 13, Time over 6000 rpm, check system, clear status, and save. The Service Form has tabs across the top with EHC data, Input, ProFet Data, Sensor Data, System Log, Input Log, ProFet log, Analog log, and RPM log. So, it doesn't sound like you have the software!
NZBigDog
I am also looking for this Smartlink software to use on the 2000-2002 bigdogs, it should let me change "curve" of ignition and show the RPM stuff as well.
Can anyone help with this?
Is anyone friends with a BD mechanic they can get a copy off?
DRBarnhart
Hopefully you'll have more luck than I did when this thread was started two years ago... :(
Dennis
pknowles
RETIRED
I would think every shop that serviced these bikes would have had this software and with things the way they are, maybe someone will step. I might get up with the guysat departure bike in Richmond, Va, and see what they have. worth a shot.
Nukeranger
Nukeranger
The Software I had didn't work on my Vista Windows laptop to connect to the Bike EHC. I have Wire Plus now. You should try working with Curtis.
